Don't do that.need some help have an 84 jimmy and the threads in the back of the trans that the transfercase bolt to stripped out would drilling it out and using thread inserts hold
Check out if there are threads left as Iceman said as that might work, but you will be fine with heli-coils in there. I HATE to contradict Iceman, but due to a screw up, my 700R4 has been running with heli-coils in the back of the trans for 37K with a 462BB ahead of it. MAKE SURE THAT YOU GET THE CORRECT PARTS AND DRILL BIT!!! If you can't find long inserts then you will have to stack two, which is tricky. Lots of aftermarket aluminum parts have inserts in the threads for durability. You could use some blue loctite on the inserts but be careful not to use too much or the insert could lock onto the bolt and come out if you need to pull the T-case.
Helicoils will work fine, but what I said takes less work, and less time, and the ones that go thru will be much better having the nut on the other end, it wil never strip again.
I would say if it's a new tranny do both.![]()
