1978Blazerk5
well, I was gonna get some stuff so I can do some Custom tranny cooler lines. Well my grandpa says I can use copper instead of steel hard lines, Is this true? Also would trans line be double flared or? I am gonna be ordering a B&M tranny temp gauge, where on the hard lines do i put the T fitting sneding unit thing, do you just unscrew the feed line and just put the fitting in there or do you gotta cut the lines? by the way this is for a TH350 if that matters?
