Hi Everyone,
I'm new to this site but I've been reading on and off for a long time. What I've learned is that many of you have either seen it or done it so I here is what I could really use your advice on.
I have a '71 GMC Jimmy w/ 350/350, 2in lift and 33" MT's. I plan on going radical and putting in a 6.6L Duramax engine with a Allison-1000 5 speed tranny. I have Three questions I have to answer before I'm successful.
First: What parts do I need to make this happen?
Second: what alterations will I need to make to my vehicle to make it fit?
Third: Given the expense of buying the components am I better off buying a wrecked vehicle? How do I find one and how much should I expect to pay?
I have a few thought on the first but no idea yet on the second so any info you can provide would be helpful.
The parts I know I need:
Engine with wiring harness, ECU, sensors, and accessories such as alternator, water pump, and fuel pump. I'll also need an adapter from the tranny to the NP205(unless you have a better suggestion)
What else? Some reading I've done suggests I need the fuel tank and the instrument panel as well.
Now how do I fit it into my truck? The allison is a big tranny so I figure I'll have to cut the hump out of the cab and reshape. What about the motor mounts? The firewall?
Thanks for your input!
i'm kidding....mostly. frame would be too long, anyway. either way, you're getting into a big project. one i'd love to see
