Fred_M1010
I tested the pulling force of my new winch today
And I must say I'm pretty baffled at the result...
I anchored the truck to a tree and hooked the cable to a scale attached to my tractor.
(Yeah, I swapped the John Deere for a Fendt a while back
The scale didn't go higher than 2500kg, so I put the winch in high gear so I wouldn't bottom out the scale.
It almost bottomed out anyway, I got 2100kg (~4620lbs)
But since I know the gear ratio of the winch, I can calculate how much it would pull in low gear.
High gear has a 35:1 ratio, and the low gear has a 256:1 ratio,
So in low gear it should pull 4620*(256/35)= 33792lbs
When I was done measuring I placed it in low gear and removed the scale
Then I was able to pull the tractor with the brakes on
Ok, it was a little snow on the ground, but it wasn't very slippery.
And here's the evidence
Has anyone here tested the pulling force of their winches?
I'm a little curious about what's normal...
