That's all OK.
O2 may be high but it is closed loop and should be doing cross counts so reading bounces high/low.
Idle is a little high but OK if in Park/Neutral.
Error 33 or 34 if still set runs Alpha N, not Speed Density. So data is no good...
For good data log you need a laptop and cable. Read the TunerPro Tutorial, you just need to worry about the data log ADX file.
http://coloradok5.com/forums/showthread.php?t=302680
You told me that was a stock motor?Anything jump off the screen. Had a low MAF/MAP error code 34. I am running the most aggressive Computer cam according to COMP CAMS.
