Trim Levels
82355
1 ton status
Bradish Nebraska
Doing some research, because it has always bothered me (and I have been stuck at home the past couple days with a sick child...), and these are the '73-'87 Trim Levels for Chevrolet Blazers, Pickups, and Suburbans.
Blazers
1973 - Custom - Cheyenne
1974 - Custom - Cheyenne
1975 - Custom Deluxe - Cheyenne
1976 - Custom Deluxe - Cheyenne
1977 - Custom Deluxe - Cheyenne
1978 - Custom Deluxe - Cheyenne
1979 - Custom Deluxe - Cheyenne
1980 - Custom Deluxe - Silverado
1981 - Custom Deluxe - Silverado
1982 - Custom Deluxe - Silverado
1983 - Custom Deluxe - Silverado
1984 - Custom Deluxe - Silverado
1985 - Custom Deluxe - Silverado
1986 - Custom Deluxe - Silverado
1987 - Custom Deluxe - Silverado
1988 - Custom Deluxe - Silverado
1989 - Scottsdale - Silverado
1990 - Scottsdale - Silverado
1991 - Scottsdale - Silverado
Pickups
1973 - Custom - Custom Deluxe - Cheyenne - Cheyenne Super
1974 - Custom - Custom Deluxe - Cheyenne - Cheyenne Super
1975 - Custom Deluxe - Scottsdale - Cheyenne - Silverado
1976 - Custom Deluxe - Scottsdale - Cheyenne - Silverado
1977 - Custom Deluxe - Scottsdale - Cheyenne - Silverado
1978 - Custom Deluxe - Scottsdale - Cheyenne - Silverado
1979 - Custom Deluxe - Scottsdale - Cheyenne - Silverado
1980 - Custom Deluxe - Scottsdale - Cheyenne - Silverado
1981 - Custom Deluxe - Scottsdale - Cheyenne - Silverado
1982 - Custom Deluxe - Scottsdale - Silverado
1983 - Custom Deluxe - Scottsdale - Silverado
1984 - Custom Deluxe - Scottsdale - Silverado
1985 - Custom Deluxe - Scottsdale - Silverado
1986 - Custom Deluxe - Scottsdale - Silverado
1987 - Custom Deluxe - Scottsdale - Silverado
1988 (R/V) - Custom Deluxe - Scottsdale - Silverado
1989 (R/V) - Cheyenne- Scottsdale - Silverado
1990 (R/V) - Cheyenne - Silverado
1991 (R/V) - Cheyenne - Silverado
Suburbans
1973 - Custom - Custom Deluxe - Cheyenne Super
1974 - Custom - Custom Deluxe - Cheyenne Super
1975 - Custom Deluxe - Scottsdale - Silverado
1976 - Custom Deluxe - Scottsdale - Silverado
1977 - Custom Deluxe - Scottsdale - Silverado
1978 - Custom Deluxe - Scottsdale - Silverado
1979 - Custom Deluxe - Scottsdale - Silverado
1980 - Custom Deluxe - Scottsdale - Silverado
1981 - Custom Deluxe - Scottsdale - Silverado
1987 - Scottsdale - Silverado
1988 - Scottsdale - Silverado
Nice list. They also had a few others like the Bonanza. A trim package that ran from about 75 through 80.
Then you have all the GMC trim packages. Confusing for most people.
Found this list on another site:
1973-1974
Base model - Chevy Custom/GMC Custom
Z62 - Chevy Custom Deluxe/GMC Super Custom
Z84 - Chevy Cheyenne/GMC Sierra
YE9 - Chevy Cheyenne Super/GMC Sierra Grande
1975-1981
Base model - Chevy Custom Deluxe/GMC Sierra
Z62 - Chevy Scottsdale/GMC Sierra Grande
Z84 - Chevy Cheyenne/GMC High Sierra
YE9 - Chevy Silverado/GMC Sierra Classic
1982-1987
Z62 - Chevy Scottsdale/GMC High Sierra (Note this change)
Z84 - Discontinued
Here is a basic explanation of the trim levels.
For 1973 to 1987 the trim level option codes for Chevy and GMC regular cab pickups followed this very general outline. They were:
Base trim (No option code)
Trim theme:
Minimal chrome trim on the outside. Inside, you will find a black rubber floor mat (no carpeting), and a basic vinyl upholstery (occasionally custom or deluxe cloth was found as an extra cost option from '82 onward). Door trim panels with basic vinyl finish, minimal insulation, a basic black bezeled instrument panel with idiot lights rather than gauges, and no headliner were part of the trim.
Lower intermediate trim (Option code Z62)
Trim theme:
This trim was a minor upgrade of the base trim described above. A little more chrome dressed up the outside. Inside, the most significant upgrades involved the use of a color keyed floor mat (vs. the basic black noted above, with carpeting only in very special cases) and a choice of "custom cloth" or "custom vinyl" upholstery. These two seat upholstery choices were shared with the higher level (Z84 and YE9) trim packages mentioned below. Interestingly, other woven/striped vinyl upholstery selections were exclusively available on this trim level in various years and included carpeting to replace the usual color keyed vinyl mat. Also, there was a little more floor insulation, and the door panels differed only slightly from base with very minimal wood grain or chrome molding additions. Still, no headliner.
Upper intermediate luxury trim (Option code Z84)
Trim theme:
This was a truly a luxury level trim and was only a very small notch below the top-of-the-line option. It represented the greatest price jump between levels, and in most years, appeared almost identical to the YE9 trim noted below. In all years, a more deluxe molding package, along with a tailgate insert for Fleetsides, was included. Inside, many major additions to the Z62 level were found, including cut-pile carpeting, and insulated full headliner, and door trim panels with large wood grain or brushed aluminum door appliqués. The door panels also had map pockets. Special hood and cab-to-fender insulators were also found here. Because of the near redundancy of this trim with respect to the YE9 level below, I suspect, option Z84 was discontinued after the 1981 model year.
Top of the line luxury trim (Option code YE9)
Trim theme:
A few minor additional exterior moldings complemented those included with the Z84 trim. The most significant outside difference was the inclusion of the V22 Chrome grill/Deluxe front appearance package as standard with this trim starting with the 1980 model year (this package was optional at extra cost with the other lesser trims). Inside, the YE9 level included the BC2 Deluxe instrument panel (a wood grain or brushed aluminum finish instrument cluster with full gauges replacing idiot lights) which was also optional at extra cost with the lesser trims. The headliner, floor carpeting, and insulation features were identical to those found on the Z84. Door panels were almost identical to those found on the Z84, although door pull straps and lower panel carpeting were added to those found on the YE9 after 1976. Finally, full vinyl trim covers replaced the lesser trim models abbreviated covers on the lower kick panels.
Interestingly, the Cheyenne name was resurrected for 1988 when it was assigned to the base trim level, replacing the Custom Deluxe name. GMC naming conventions changed entirely to SL, SLX, and SLE. Today Silverado/Sierra no longer refer to trim options, but instead are a model reference to the Chevy/GMC pickup line.
There were some other less common trim packages which overlapped those noted above. They included the Z77 Chevy Sport/GMC Street Coupe exterior graphics packages that exclusively used the Z62 trim interior appointments with the addition of the floor carpeting and the V22 Deluxe front appearance option, and the BC2 Deluxe instrument cluster. The Z77 option, which also included N67 Rally wheels as standard, was available only on the 1976 to 1981 Chevy/GMC short bed 1/2 ton pickups. GMC offered some other interesting limited edition models during the 1975 to 1987 time frame, but I won't get into those here.
Also offered were several Chevy Bonanza/GMC Royal Sierra option groups. They were special year-end promotional packages (analogous to Ford's old "white sale" Explorer pickup packages) with special discounted price groupings of popular appearance/convenience options. Prior to the 1980 model year, the Bonanza/Royal Sierra packages were based on the Z62 trim level with the addition of floor carpeting; after that time, the packages offered a choice of Z84 or YE9 interiors. In later years, Canadian customers were offered similarly conceived "Wrangler" packages. The Wrangler packages included some very distinctive and exclusive paint/decal features; really neat collector's items!
Some of the trim items found in higher priced trims were optimally available in the lower level trims at extra cost. Most (but not all) of the exterior moldings found in the Z84 and YE9 packages were either available separately or as part of the various two toning paint options on the base and Z62 trims.....ditto for the popular V22 Deluxe Front Appearance option, and BC2 Deluxe Instrument Cluster. Other common appearance options included a fancy 1973 to 1981 bucket/console/carpet combination available with (essentially) all trim levels and various wheel/tire options.
Bonanza was actually an end of year sales promotion. If you look on the SPID of a Bonanza, it will list the actual trim level the truck was ordered with. I have seen Cheyenne and Scottsdale Bonanzas, I have never seen a Silverado Bonanza. Not sure if they exist or not.
Martin
You're right. I was thinking of the Bonanza badge on the truck was trim in a sense but I realize its just a Scottsdale. Always thought it was a weird name along with Royal Sierra.
Found this info:
Bonanza special promotional grouping of options. It was offered during the 1976, 1977, 1978, 1979, and 1980 model years, and was typically offered during the final months of those model runs. There were several packages (typically designated "A", "B", "C", etc., and respectively carrying increasing levels of included equipment) offered on a variety of truck models. Equivalent packages were offered for GMC vehicles under the "Royal Sierra" designation.
With the exception of the 1980 model year, the packages for the pickups were based upon the Scottsdale trim package, and with the exception of carpeting and nameplates and discounted option prices, resembled other similarly optioned non-Bonanza Scottsdales offered during those years.
The specific packages for 1979 Chevy Big 10 pickups were as follows...
Package A (code YG6) included Scottsdale trim, Bonanza nameplates, color keyed carpets, striped vinyl bench seat, deluxe wheel covers, chrome grille, upper and lower bodyside moldings, clock and gauges, AM radio, inside hood release, automatic transmission, comfortilt steering wheel, intermittent windshield wipers. The total savings for package A was $200.
Package B (code YG7) included all items for package A plus tinted glass, air conditioning, cargo lamp; package savings was $300.
Package C (code YG8) included all items in packages A and B plus operating convenience group (power windows and door locks), speed and cruise control; package savings was $400.
Interestingly, the Scottsdale offered three different upholstery choices. They were Custom Cloth, Custom Vinyl, and Striped Vinyl. The Custom Cloth and Custom Vinyl options for non-Bonanza Scottsdales included a color-keyed rubber floor mat while the extra cost Striped Vinyl selection replaced the mat with carpeting. The Bonanza default upholstery was the striped vinyl, but I believe the Custom Cloth and Custom Vinyl could also be specified for the Bonanza without forteiting the carpet.
There were plenty of "sticker options" over the years. The Gentleman Jim, Big 10, Heavy Half are three I can think of. For the newer pick-ups, at least around here the one that irritates me is the "GFX" package. Yeah, active aero and ground effects on a pick-up. I'd pay way more for that!
Big Ten and Heavy Half were just emissions work arounds. They could be ordered with any trim level.
Martin
Service parts identification decal. Usually inside glove box door. Has all the RPO codes for installed equipment
Sometimes under the hood on the top of the inner fender well.
Martin
