I thought I had it down pat and it was going good. Intalled the dizzy at top dead center, and put the rotor at one and adjusted the ones yours supposed to adjust, then turned the motor until the rotor was at number 6, and then adjusted the others. With the motor at #6, some of the rockers I adjusted previously were loose, some more than others.
What did I do wrong?
I installed Comp Cams High Energy Hydraulic Flat Tappet cam, Vortec heads, and GM Self Aligning rockers.
Man, you didnt do anything wrong. This is what happened. When you adjust them, you very slightly compress the plunger, and it is set, or "pre-loaded" Over a few minutes, the preload will push some oil out of the lifter, and cause it too feel loose, you "bleed-down" the lifter. If this happens and you think to yourself "oh, i havnt done that one" and adjust it again, it will now be too tight.
As soon as you start the motor, the ones you adjusted, and are now loose, will pump back up, and be set.
This is very difficult for me, becuase i always second guess myself, weather its setting lifter, or locking the door to my house, i always go back and check.
You just have to have confidence in yourself, and know which ones you already set.
If they are too loose, when the motor starts they will tap, and you just simply put 1/4 turn, or half a turn till the tapping stops.
Also, if your using the regular rocker adjusting nots, and not poly locks, try to keep the adjsuting to a minimum. The old style adjusting nuts, are soooo tight on the rocker stud, that they wear away the threads fast, and your adjustments wont last long.
