I tore down my steering column to tighten the tilt bolts. that part seemed fairly simple, i felt like i had it back together but i could not get the key turn the ignition. i tried for about an hour trying to get the tumbler to line up with the gear. i could only get it to slip in when i had to rotate the ignition nearly to the acc position. after that i was unable to get the key out unless i pried it back to the acc position. Also, there was never any resistance to when the key would be in the start position. it would not bounce back. my guess is that the tumbler is toast? but i am wondering if i missed something further back in the ignition gear.
and runs between the tubes until the dash, there you can see it
