Next up on my list of projects for my 87 k5 is to try and get the cruise control working. I think i have a direction to look first, but don't know how to go about it. So I noticed when I was replacing dash bulbs the bulb for brake light was missing. Didn't think much about it, but when i put a bulb in there it would stay lit up all the time when blazer was running. Didn't recall any brake issues at the time so i just removed it instead of trying to look into it more... Now I'm thinking the fact the brake light is essentially always on if a bulb was in it, that that could very well not allow the cruise control to engage. Seem plausible? So how should i go about troubleshooting the brake light? Parking brake engages and disengages normally i feel. I've seen a proportioning valve being mentioned that could be an issue. i located it under the fan shroud, no leaks. i tapped it with a hammer, but that was it... There is an electrical connection on it. I didn't know if i could just remove it and see if the light goes off, and cruise works? Do i just pry it with a screwdriver to remove it? I attached a pic of an example for reference.
If anyone has any different thoughts on where i should look, i'm all ears.
