Truck Avenger
Should I buy a Holley Truck Avenger before the Bash
  • yes they set up easy
    Votes: 0 0.0%
  • no to much work b4 bash
    Votes: 0 0.0%
  • you drive nekkeid so it doesn't matter
    Votes: 3 100.0%
  • Total voters
    3
  • Poll closed .
What's on there now?
Just like just about anything they aren't a bolt on and go carb (even if the manufacturer tries to make it sound like they are).
Turn the air fuel mixture screws in till the bottom, don't kill it either, just till they bottom. then turn them back out 2 and 1/2 turns, then we can adjust from there. Thats assuming your infamous Holley floats are not saturated and half way submerged. but, even then that should not affect how it idles, just how it runs off camber and under load.
It idols fine just not sure the off camber is what it used to be ran great last year just seems to not this year.
