Eric M.
Got a problem and need some help!
87 V3500, 454, fuel injected.
If I don't drive my truck for a week or so, it won't start up. It'll crank just fine, but no fuel is pulsating from the injectors. It use to be that I could jump it and it would start right up. I can turn it off right after it fires and it'll start up just fine again. I thought the battery voltage was low preventing the computer from sending a signal to the injectors and that was why it would fire up after jumping. The last time it happened, I bought a new battery and it started right up. I changed altinators thinking that was the issue.
Now here I am, with the same problem. This time, jumping wasn't enough, I ended up using a plug in battery charger / starter while jumping and it still took a while to fire. I'm thinking it may not be a voltage issue.
Any ideas what whould prevent a signal being sent to the injectors after a truck sat for a while? And why does it cure itself right after (at least for a few days)?
NOTE: Truck has 2 tanks,I have switched tanks while this was happening. Same problem with both fuel pumps ... I havn't checked the ful pump relays, kind of thought the worked or didn't, no intermitent stuff with relays.
Thanks,
Eric M.
Thanks,
Eric M.
