Hey guys, hope y’all had a great thanksgiving!
So My mechanic friend told me not to do the distributor unless I’m doing an ACDelco, but I couldn’t get my hands on one, so I decided to do a new ICM, cap and rotor, all ACDelco and I got them for cost same day. Anyways, I tested spark prior to and after the swap. Spark was and remains weak, orange in color. Still no fuel at the injectors. I also tried the eprom trick to no avail. Rechecked my fuses, my wiring, and my plugs, nothing obvious. Checked resistance at the pick-up coil wiring, around 600 ohms (im told 500-1500 is expected and normal?). Mechanic friend says the ECM doesn’t control spark at start-up cranking so it wouldn’t be ECM related, said the fact that it happened suddenly after a bump could have been a fluke. Had a wire tap at ECMB fuse that had a bare stripped wire on the end under the carpet laying on the floorboard, that fuse had popped, so I replaced it with the fuse for my trans for trouble shooting purposes.
My truck had a problem with super low idle and stalling out and the fix was to disconnect the timing advance bypass wire (tan and black), and it ran fine after. I drove it like that. Then this happened. I figured the distributor needed to be replaced but if still drove so I was gonna wait til I could afford a Delco.
One odd thing to note: with the timing advance bypass wire disconnected I SHOULD be getting a code 42, but, I’m not. I only have codes 81/82 from pulling my trans fuse. Im wondering, is this a sign of a bad pick-up coil? Or yet another symptom. So frustrating! I’m either going to order a $300 ACDelco or im going to buy the in-stock duralast gold distributor and swap my new ACDelco parts on before I drop it in. But I’ve seen nothing but problems from people who went aftermarket instead of OEM for distributors on TBI’s… and I could really use the extra $150 these days…
Anyways, any continued help is much appreciated!!!
