blackk5350
i swear to the almighty im going to burn the damn thing. ok besides this happening its like 15* outside heres the deal.
throws a code 44(lean) if that has anything to do with this stuff
Well about a week ago the volt meter starts acting up (showing wrong voltage) tested with volt meter battery has 14volts then if i start it with some acc's on it drops to 12.XXv. good right?
about a week ago the throttle starts acting funny and every so often i press the gas to go and it takes about a second to go(wont rev) then catches adn goes,not transmission. so i guess you could say it has bad throttle response(usually happens hen taking off.
MAIN PROBLEMO: tonight,cold as balls mind you, driving in the snow driving ok, pull into driveway(flat driveway) and it just dies, and cant get it to start back up. Ran the battery down to low to get it started back up from cranking it so much. so now it is sitting in my driveway with bad throttle response, wont start(maybe starter) bad volt meter and wont start. it WILL turn over though, barely. help me please only vehicle and im pissed
*ok well i got it started, looks like it was battery terminals. NOW it is running very weird at idle. almost dieing when i shift from park to reverse drive ect. so how do i fix the idle
not too happy, but will run on that.
