2toneZ
Registered Member
The retaining fingers for the MAP sensor are super small & brittle on truck LS intake manifold. I now have 2 intakes with broken clips. Is there a consensus fix for this situation?
At this time I figure I will plug the sensor into the manifold & leave it as is, because the manifold is under vacuum it should be held in place. Maybe a little RTV to adhere it in place would be appropriate.
What do you guys do?
