TB
Newbie
Hey guys
First post here (sorry its so long!), I did some searching but found a lot of mixed opinions... I'm a car guy into Autocrossing and HPDE (road course) and I do all my own work on my cars... but I'm relatively new to 4wd trucks, so I'm looking for advice/guidance...
I have a '91 K5 that was bought new by my dad. Around '94-'95 he put a 2.5" lift (has Rancho shocks, thats all I really know for now until I chat with pops) with 33" tires on it, but other than that its basically a stock TBI 350. He used it for a fair amount of light-meduim duty off roading (hunting, camping, etc). Then starting around 2001, he bought another truck and this one sat in the garage. And sat. And sat. He would take it around the block, freshen up the fluids, etc, but it saw almost no use. So now its basically a stock TBI 350 K5 with a 2.5" lift from '95 and 110k miles and thats it.
So now to help my wife and I out with a second vehicle, he's given it to us for a ridiculously low price and I'm trying to cure a few issues and freshen it up a bit. The truck will see very little light off-road use(1-2 times a year for now) so I want to make it as streetable as possible while keeping the lift and tires. In other words, I'm looking more for comfort and safety (my wife will be driving it a lot) over off-road capability. Looking for input on whether or not I'm on the right track...
Initial issues I noticed:
1. Tramlines down the road badly. (FIXED, see below)
2. Poor braking, and pulls to the right on hard braking. Brake pedal gets hard with engine off, but seems overly spongy with the engine running.
3. Occassionally dies at a stoplight (FIXED, see below)
4. ROUGH ride, lots of body roll
5. Loose steering, lots of play on center (FIXED, see below)
6. Slow leak a bit from the middle of the truck (FIXED? see below)
Initial things I did:
-New tires. 10 year old tires arent good for anything. This helped Issue 1 quite a bit.
-Changed Oil/Filter, F&R diff oil, TCase fluid, Coolant, Brake fluid, Air filter, lube
-Had the alignment checked, shop says everything is within spec and that ball joints and tie rod ends look good.
-Replaced steering stabilizer shock and slightly tightened the steering box adjuster... helped Issue 5.
-Changed the Fuel Pump after the truck finally stopped idling all together... fixed Issue 3.
-Replaced the rear TCase seal... I think this has solved Issue 6
-Replaced the front pads and calipers. Stops better, pulls less on hard braking, but still pulls.
-Did the drum adjustment technique (several hard stops in reverse). The drums have enough power to skid the rear tires on pavement in reverse.
Next:
1) Brakes. I want to get the brake pull and spongyness fully sorted out first, so I want to replace rear shoes and upgrade to SS lines, as I'm sure the old rubber isnt helping my brake pedal feel. I havent noticed any leaking out the back of the drums, but while I'm doing the shoes I'll just take a look at the wheel cylinders for anything out of the ordinary. Any other recommendations? The Master Cyl has never been run low/out of fluid, so I'm not too worried about it...
2) Shocks. I'm pretty sure these 15 yr old shocks are blown and I want to replace them. Can someone recommend a replacement shock set for me? I dont want/need top-of-the-line off road monster shocks... I'm looking for the best on-road ride I can get for UNDER $150. I saw Rough Country Hydro 8000 are about $120 for the set, and they claim "superior highway ride"... but then some people say they are pretty rough. Ranchos are a bit more expensive, and I've heard they ride rougher than the RC's. Any other recommendations in my price range?
Thanks for any help you guys can give!
Next:
Fronts have new pads and calipers, but the rotors now feel like they need a resurface as well.
