xsmokey11499x
ok so an update on my truck now, is That, I replaced the starter with a brand new one. Not reman. Ran all new wires, that the starter uses. Sanded the mounting surface on the block.
My truck will start fine, Then I will drive a bit. shut it off. When I go to start it, It's just a real weak crank and wont crank over the truck.
I've tried several different batteries.
and same effect. Just weak cranking.
