k well got it runing.....no more flames coming out of carb do to the new rocker nut i put in....but in order for me to drive it....i have to have the timing so far advanced its to the point were timing mark is on other side of balancer..when timing at 12* it just back fires out of the carb and barely wants to move but with it way advanced it runs good tho, dont over heat, takes off good...dont feel like im geting full power tho. (but not sure what to really expect with 35's that measure bout 33's and 4.56 gears and th350 and welded 14bltff)......when i checkd the valves they seemd like they were opeing in the rite places tho....like the cam was in right...im goin to check and make sure im not a tooth off on the dist.any other ideas?...could the carb be too rich??????
so if the dist comes out to be in right....and the cam *could* be off....what should i do? since its runs pretty good with timing so far advanced....
