Flhftw
Registered Member
85 k5, 87 gen 1 350 with 70’s double hump heads and Comp cam through a 700r4, with 6al msd and coil in a stock hei
hey guys here’s a long one
A few weeks ago a changed out a bad engine with a used one that had been cammed and it’s been nothing but one headache after the other but yesterday I was able to get the timing valve adjustment and idle dialed in yesterday(or so I think). Truck idles good around 800-900 rpm at 10* btdc and 36* advanced.
One thing I noticed however while adjusting the valves is that the tdc notch is close to 90* before the #1 piston is at the top. I don’t know if this common but on my last engine it was off also and I had to time it by vacuum.
Anyway when I put it in gear the idle drops to around 500 rpm and is close to stalling and sometimes will coming to a stop but drives and advances great with throttle
-First thought is vacuum leak but all my lines and fittings are new and tight
-then there is the timing notch issue
-header burns on some plug wires
-possibly a torque converter issue (I had driven it about 3 miles with improper kick down cable adjustment before I figured it out)
-maybe air/fuel mixture (along with the new engine I installed a ready to run 600cfm Holley carb with all the necessary brackets)
-maybe pcv but it’s new, also have a blocked off egr
I was thinking I would start by painting a mark on the damper where the actual #1 tdc then go about timing from there... I need help with this one
