Iliektruks
Hello all,
I’m having issues starting my truck. I recently rewired the truck and when I went to start the truck it worked until it stopped. I changed the starter thinking that was it but after I changed it I tested the starter and it worked fine. I’m replacing the fusible link wire to verify that wasn’t it. When I do go to start it. The truck power dies until I reset power for the truck. I checked the grounds from engine block to cab, alternator bracket to battery, frame to core support(i reattached it). All the grounds were checking good after. I’m not sure what else to do at this point any help would be great.
The starter just makes a click then power dies also.
