Truck Trailer
91 Jimmy
Registered Member
Michigan
I'm looking at trailers to haul my Jimmy around. I have it down to 2 different trailers, one is all steel and the other has a wood floor. Which one should I go with? Also, is there anything else that you would recommend that the trailer have from your past experiences? Thanks guys
I have a 20' with a 4' dove tail. It is a steel frame with wood floors and a hydro lift and I love it. I would recommend the wood floor over the steel because it should be lighter and save you gas.
get an weight distributing, equalizing hitch setup.
never need an equalizer with a 20 footer
????hows that again?
We jsut towed a 24' to Fla. and without the weight distributing hitch we would have had 1400lbs tounge weight on the ball.
I have an 18ft "big tex" with wood deck, which I had to replace w/pressure treated lumber after the original wood rotted, other than that it works great even with my 3/4 ton on it
