truck wiring...
84gmcjimmy
1 ton status
B.C. CANADA
I don't need a wiring diagram, I want to know if there is a book, or somewhere I can read so I know alot more about wiring and electrical stuff... I plan on taking camok5 right off the frame, so there is going to be a bunch of wires... and I need to know how to wire it back up again... and lose some of the wires, add some lights, re-wire the batteries to behind the seats...etc!
can anyone help?
You should be able to find some books on auto wiring basics at any major bookstore. Radio shack has some stuff on basic electrical theory and wiring. If you have a Barnes and noble I'd look there first. /forums/images/graemlins/thumb.gif
my brother in law let me borrow his little books on basic wiring,they are for building hot rods so its perfect(eliminating useless sh!t like we do). let me go get out of the garage. /forums/images/graemlins/grin.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
i can't find them,i'll look tommorow and give you the name and number or address. /forums/images/graemlins/grin.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
Want a tip? You can never have too many fuses. If not your truck which you just painted, put a new motor in and made a new interior for can burn down real fast. Please do not ask me how I know.
-Chris
these little books are sweet,they explain it so simply a two year old could do it. /forums/images/graemlins/grin.gif talk yo you tommorow. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
I don;t know if I should be saying this, but i want to re-do the whole wiring thing, with new wires, replacing the old worn stock ones... and adding things on the way...so I need a book so I know how to do it.
wen i rewired my truck, i just ran a ground to the light (or whatever your wiruing up) then a wire to a fuse, then to a switch, then to a positive, i just ran everything liek that, and its been werkin out fine. /forums/images/graemlins/grin.gif
I'd like to re-wire my blazer someday. It's a CUCV so there's a ton of wiring I no longer need. Not to mention no longer having the diesel. I know that Painless makes some generic kits. I know one key is to get wires that will stand up to the engine compartment.
So I would be interested in the books also.
Pretty hard to improve on the stock stuff to be honest. If the wiring harness hasn't been abused (like that ever happens) your better off just working with it and adding what you want.
To do the connectors alone with the same GM used, which has worked for 20+ years, is pretty expensive and is time consuming.
as long as not a bunch have been cut in the past then you should be just fine, just unplug everything and remove the harness from the cab or front clip, and put them away for now, maybe put tape in a couple places so you can note where that part of the harness was laying int eh cab or clip
