jteck10
That’s exactly what is happening. The loud thud is clear in the video above. Thanks againAll of my post are based on "hear a loud thud and won't crank"
If the engine is turning over.
Then it is not hydro locked.
will do.Missed the video first time around.
I can't tell if the engine is hydro locked, or if and electric issue.
Get a breaker bar and 5/8 deep socket to see if you can turn the engine by hand.
Use the center bolt bottom pulley.
I assumed it was typo, but just makin sure - you know more about K5's than me!Yes thank you I will fix it
I thought that initially too, I took my battery in to get tested and fully charged. They said it was good but it’s weak and on it’s last quarter of life.I assumed it was typo, but just makin sure - you know more about K5's than me!
Watching the original vid, my gut says battery not giving enough amps..... Have you tried jumper cables attached to another car? Or a fully charged jumper box?
You already put a starter in.... all the grounds are good?
Ok, I’ll try to get under there and turn by hand with everyone connected and plugs in to see if it movesWell if you can't turn it by hand with the plugs in it is hydro locked.
This will tell us if your engine is hydro locked, or has an electrical issue in the cranking circuit.
No. If problem was in that area, it would be cranking but not firing.Just thinking out loud here. Any chance this is a distributor/rotor issue?
good point. nevermindNo. If problem was in that area, it would be cranking but not firing.
How long did their test take? A proper trickle charge takes like 24 hours. I have had auto parts stores take my battery for an hour and tell me that is good, when it ended up being bad. It's not unusual for a battery to test good on their little computer but then fail under a real-life load.I thought that initially too, I took my battery in to get tested and fully charged. They said it was good but it’s weak and on it’s last quarter of life.
ah good call, they did keep it for about an hour. ill try jumper cables if im able to turn it by handHow long did their test take? A proper trickle charge takes like 24 hours. I have had auto parts stores take my battery for an hour and tell me that is good, when it ended up being bad. It's not unusual for a battery to test good on their little computer but then fail under a real-life load.
That's why I asked if you've tried jumper cables. If it fires with jumper cables connected to a good running car, then it's bad battery
@fordsucks! Here’s the latest. Got under the hood and turned the crankshaft pulley no problem manually. Instead of trying to jump it, I just went and got a new battery since the last one was on its way out. I got an optima red top with a good amount more cranking capacity.Well if you can't turn it by hand with the plugs in it is hydro locked.
I only cranked it for a min or two. Let off for the night. Any idea what next steps are?That fuel on the exhaust is a clue the cylinders were pushing fuel out the exhaust. Good time to cease trying to start it for today
Also, open the filler cap and make sure the tank is not pressurized
Seeing as the coil was probably never replaced on this thing, I’ll probably do :Yes
Wait until tomorrow
Unplug the wires to the injectors
Change the oil
Troubleshoot why you have no spark
1 - coil
2 - rotor
3 - test coil for power
4 - replace the plugs, probably pretty wet by now
