K5dreamer
FML my last post got lost when i hit submit. ok, short version.
I read through a few threads on the lack of accuracy of claiming a crawl ratio based on drivetrain ratios. And how tire size impacts the actual crawling performance of your rig. Lots of good information and debate, but no one actually put it into a formula that was clear and easy to use. I have spare time at work.... lots of it, so i decided to do just that. I set it up to give you a number similar to an RTI score, in three digit form, that could be easily expressed. For instance my RPI score (rotations per inch) is .114, or 114, or one hundred fourteen. I also did a formula to calculate your speed at idle with the vehicle in gear. Enjoy.
Variables
CR - crawl ratio
C - Circumference
F - transmission first gear ratio
Tc - Transfer case ratio
A - Axle gear ratio
Td - tire diameter
P - Pi or 3.14
I - rpm at idle
MPH - miles per hour
RPI - rotations per inch
Formulas
CR = (F)(Tc)(A)
C = (Td)(P)
CR
--- = RPI
C
((I)/(RPI))
-------------- = MPH
1056
EDIT - reduced the last equation to make the math simpler. reduced 60/63360 to 1/1056.
Variables
CR - crawl ratio
C - Circumference
A - Axle gear ratio
Td - tire diameter
P - Pi or 3.14
I - rpm at idle
Formulas
CR = (F)(Tc)(A)
C = (Td)(P)
CR
--- = RPI
C
((I)/(RPI))
1056
