driver side of block on bell housing area just under the head surface is the BLOCK casting # . this gets you started . as some engines share blocks or cranks to get the end cid of the motor .
if a crate motor almost a good luck unless paper work or tear down to see whats inside it.
if its a good runner then you have a runswell motor .
