Trying to pick up some used tools.... good deal?
hoodride
Humboldt, CA
He's asking $400 for all of this. Sounds like a good deal for the Snap On stuff alone, but fill me in...
ITEMS LIST:
TOOL STORAGE
1 Snap-on heavy duty roll away cart KRA 307F
WRENCHES
14 Snap-on wrenches, combination, standard length, 12-point, Metric, flank drive plus, chrome, 8mm to 22mm
4 Snap-on wrenches, combination, standard length, 12-point, Standard, flank drive plus, chrome, 5/16" to 9/16"
6 Cresent wrenches, combination, chrome, 8mm, 10mm, 12mm to 15mm
6 Cresent wrenches, combination, chrome, 5/16" to 5/8"
1 (off brand) wrench, modified combination 1-7/16" on open end, used for special import car oil application
1 Matco wrench, adjustable oil filter wrench, 3/8" drive, #OF636
1 custom fabricated oil filter nylon strap wrench, 1/2" drive, fits most any size
18 Cresent wrenches, L-shaped, hex, Standard and Metric
1 Craftsman wrench, battery terminal tool, ratcheting box wrench, 5/16", 1/4"
2 Craftsman, adjustable wrench, drop forged, 4", 8"
SOCKETS
3 Matco sockets, 1/2" drive, flip socket, thin wall, 3 piece set, impact, 17mm-19mm, 19mm-21mm, 3/4"-13/16"
4 Kal tools sockets, 1/2" drive, deep, impact, 8 piece set (4 missing), pieces included in set are 7/16", 1/2", 9/16", 7/8"
10 Cresent sockets, 1/2" drive, shallow, chrome, 15mm, 17mm, 18mm, 19mm, 21mm, 1/2", 9/16", 5/8", 3/4", 7/8"
1 Mac socket, 1/2" drive, shallow, impact, 1"
1 Snap-on socket, 1/2" drive, shallow, chrome, 15/16"
1 Snap-on socket, 1/2" drive, universal impact joint, #IP80C
4 Snap-on sockets, 3/8" drive, semi-deep, 12-point, chrome, (two)10mm, 1/2", 9/16"
12 Snap-on sockets, 3/8" drive, shallow, 12-point, chrome, 8mm to 19mm, 1/2"
1 Snap-on socket, 3/8" drive, universal impact joint, #IPF800A
9 Cresent sockets, 3/8" drive, semi-deep, chrome, 12mm to 15mm, 17mm, 7/16", 1/2", 9/16", 3/4"
16 Cresent sockets, 3/8"drive, shallow, chrome, 5/16" to 3/4", 10mm, 12mm to 15mm, 17mm, 19mm
16 Cresent sockets, 1/4" drive, shallow, chrome, 3/16" to 9/16", 9/32", 11/32", 10mm, 12mm to 15mm, 17mm, 19mm
1 Snap-on socket, oil filter, 3/8" drive, 1-1/4" (32mm), #A106
1 Snap-on socket, pipe plug, external 3/8", chrome, #PPM412A
1 Snap-on socket driver, metric, hex, Standard, 10mm, #FAM10E
1 Snap-on socket, spring cap, 1/4" drive, #S6118A
1 Creseent socket, spark plug, chrome, 5/8"
7 Accutorg torque socket set, 1/2" drive, 7 piece set, includes 13/16"/100ft-lbs, 21mm/80ft-lbs, 19mm/80ft-lbs, 17mm/80ft-lbs, 19mm/65ft-lbs, 21mm/60ft-lbs, 17mm/55ft-lbs
ADAPTORS
1 Snap-on adaptor, 1/2" drive internal x 3/8" drive external, impact
1 Snap-on adaptor, grease gun, angle lube, 90°, #YA799
EXTENSIONS
4 Cresent extensions, 4 peice set, chrome, 1/2" drive x 4", 3/8" drive x 5", (two) 3/8" drive x 2", 1/4" drive x 2-1/2"
RATCHETS
3 Cresemt ratchet, sealed head, combination drive, chrome, 3 peice set, 1/4" drive, 3/8" drive, 1/2" drive
1 Snap-on ratchet, speeder, 3/8" drive, chrome, 17-27/32". #F4LB
AIR TOOLS
1 Craftsman impact wrench, air, 1/2" drive, model 875-188840
1 Marvel air tool oil, 4oz
1 Snap-on blow gun, #JT13
HAND TOOLS
1 Maglite flashlight, blue billet, 3 D-cell
1 (off brand) stylus LED pen light, 2 AAAA-cell
1 Snap-on mirror, telescoping, 3-1/4" mirror, #UIM325
1 Snap-on mirror, telescoping, 2-1/4" mirror, #UIM225
1 Matco hammer, 24oz, #2 ball peen, dead blow, #BH32DB
1 Matco hammer, 45oz, dead blow, #DB35
1 Snap-on prybar, striking, red, 18", #SPB18R
1 Snap-on timing vbelt tool, #YA9417
1 Matco hood holder, #HH4
1 Matco screwdriver, slotted, chrome top torque II screwdriver, green, 5/16" x 6", #SPO106C
1 Matco screwdriver, slotted, chrome top torque II screwdriver, green, 1/4" x 4", #SPO84C
1 Matco screwdriver, slotted, chrome top torque II screwdriver, green, 3/16" x 3", #SPO63C
1 Matco screwdriver, phillips, chrome top torque II screwdriver, green, 1/4" x 4" #2, #SPG84P2C
1 Matco screwdriver, phillips, chrome top torque II screwdriver, green, 3/16" x 3" #1, #SPG63P1C
1 Cresent screwdriver, dura-driver magnetic bit driver, 1/4" x 4"
4 Cresent screwdrivers, magnetic, 4 peice set, includes 1/4" x 4" slotted, 3/16" x 3" slotted, #2 x 4" phillips, #1 x 3" phillips
44 Cresent screwdriver, driver bits, magnetic, 1", includes slotted, phillips, torx, and hex bits
1 pocket screwdriver with magnet
1 valve core removal tool
1 Matco pliers, oil filter pliers, 2-3/4" to 3-1/8", #MST105
1 Matco pliers, oil filter pliers, slip joint, 2-1/4" to 4", #OF5075A
1 Snap-on pliers, combination slip-joint, 6-7/16", #46ACP
1 Snap-on pliers, adjustable joint, straight serrated jaws, 12-3/4", #AWP120
1 Snap-on pliers, hose clamp, swivel jaws, 5-1/2", #PHP3
1 Snap-on pliers, vice-grip, locking, long nose with wire cutter, 6", #LP6LN
1 Snap-on pliers, locking c-clamp, 12", #VGP12412
1 Cresent angle cutters, 6"
1 Matco scraper, ridged chisel scraper, 1-1/4", #SC40CH
1 Snap-on pick, hook tip, 7-5/16", #YA145-3
1 Snap-on pick-up tool, magnetic, flexible, 24", #DPTM24
2 KD tools fuel and AC quick disconnect tool, sizes a-f
1 Snap-on spark plug gauge, gapper, #FB361A
1 Snap-on disc brake tool, spreader, #GA395
1 Snap-on brake spring tool, bendix, #BT11
1 Snap-on race punch, oval bearing, 6", #PPC6LB
1 Matco brake clip tool, #BCT48
1 Snap-on wire brush, 13-3/4", #AC58D
1 Snap-on hand scratch brush, 7-7/8", #AC5B
1 Snap-on bettery terminal brush, #BTC3A
2 (off brand) gauge, tire pressure, pencil, 10 to 50 psi, 10 to 150 psi
1 grease paint stick
2 cheater bars, 18"
2 flexible steel measuring tape, 12'
1 wooden ruler 12"
1 standard calculartor, solar
ACCESSORIES
1 Folding shelf 18"x18" to fit the side of the Snap-on KRA tool box, cant make out the brand name.
1 Snap-on socket holder with posts, 3/8" drive, Standard, red, 1/4" to 1" range
1 Snap-on socket holder with posts, 3/8" drive, Metric, grey, 6mm to 20mm range
1 Snap-on socket holder with posts, 1/4" drive, Standard, red, 1/8" to 5/8" range
1 Snap-on socket holder with posts, 1/4" drive, Metric, grey, 4mm to 15mm range
1 Snap-on wrench organizer, soft grip, standard, red, holds 12 wrenches
1 Snap-on wrench organizer, soft grip, reverse, grey, holds 12 wrenches
1 Snap-on 24" magnetic bar
1 Matco magnetic parts tray, quad mighty mag tray, #SX7040M
2 Matco magnetic parts tray, round, #SX7000M
1 Snap-on ear protectors, headphones, #GA3000A
1 Snap-on ear protectors, ear plugs, #YA160A
2 Macks ear protectors, ear plugs (2 packs)
1 Red Kap jacket, tecnician jacket, black, XL
1 Snapon kneepads, hard shell, XL
BOOKS
1 exclusive and rare "SS012: catalytic converters and oxygen sensors" study guide, 1999
1 Motor age ASE certification self study guide, test A1 engine repair, 1996
1 Motor age ASE certification self study guide, test A3 manual drive train & axles, 1996
1 Motor age ASE certification self study guide, test A5 brakes, 1996
1 Motor age ASE certification self study guide, test A6 electrical/electronic systems, 1996
1 Motor age ASE certification self study guide, test A5 brakes, 2001
1 Motor age ASE certification self study guide, test C1 automotive service consultant, 2005
1 Motor age ASE certification self study guide, test X1 exhaust systems, 2003
1 Haynes techbook, fuel injection 1986 - 1999, 2000
1 Haynes xtreme, sport compact performance, 2003
Wow, you typed that all out?
Sounds like a good deal to me, but i didnt' read the details. A couple snappy wrench sets will cost you $400, so i'd go for it. A good start anyways, just don't blow your whole tool budget on this, as im sure you will find things oyu still need.
Good start though!
That is a screaming deal. Just the first set of wrenches alone will cost almost that much. Have you actually made contact with the seller to find out if that is the correct price?
I just took a look on Snappy's website and a set of metric flank drive plus wrenches 10-19mm are $311.60
If you haven't bought these yet, you better hurry or they will be gone.
:haha: No way... just a copy/paste of the craigslist add... this guy must have done a serious inventory check to figure all that out.
Ahh, ok, duh, I guess we didn't think of that :D. Jump on it mang! Pics if ya get it all.
Yeah I`d jump on that. I bought 3 boxes with tools for $400, last year, I made about $2K, and kept a bunch of stuff. Used brand name stuff is the way to go, they work the same, and have the same warr.
The only thing I'm hesitant about it that there's no way for me to warranty the used snap-on stuff. I don't work at a shop, and I'm not the original owner (snap on direct told me that they won't warranty tools unless you're the original owner). I've heard of people being able to warranty the tools if they have a snap on dealer with an account that they've spent some cash on. I realize that it's a good deal non-the less because of the quality of the tools, and that in all likelihood I won't break them, but any one care to comment?
I have never had a Snap-on account but i have bought a bunch of Snap-on tools second hand from e-bay and have warrantied a tool a few times with no questions asked. Whoever told you they won't warranty tools except to the original purchaser doesn't know what they're talking about (Snap-on direct in your case). The tools in question are probably gone by now anyways so it really doesn't matter.
