blazin_blazer
when you rotate steel belted tires, you swap front to rear, never.. side to side,(unless you remount tire on rim backards),so not to reverse rotation of tire b/c steel belts get stretched in that direction and reversing will cause wires to break and start sticking out of tire!
w/tsl bias ply tires...is this a concern? i just bought a set of tsl 44's and have no idea which was right front or left front or rear? i always mark rotation on tire when i pull them off(no matter what kind,..RF,LF,RR,LR), but po didn't do this...he said it didn't matter on bias ply, only if they are steel belted...is this true?
