K5dreamer
well, ive been banging my head against the wall trying to learn how to bend tubing without destroying it. Finally just made an ugly 90* elbow from the lift pump and ran soft line out to the frame rail, and up the firewall as far away from sharp edges and hot manifolds as i could so i can at least start the truck and move it if necessary. On the plus side the truck runs great, obviously i did have an issue with the old lift pump whatever that may have been (worn out spring, hole in the diaphram, etc. etc.)
In any case, i will still need to bend a hardline to replace the old one that broke. So..... someone asked me to post a pic of the worthless POS bender i was using that was destroying all my fuel tubes.
this link....
http://www.sears.com/shc/s/p_10153_12605_00999090000P?keyword=tubing+bender
is almost exactly what i have. but i bought mine from advanceauto parts, and it has a red rubber grip on it instead of all metal (ouch).
Its worthless. or maybe im just using it wrong... i dunno, anyway, i had bought it on an impulse without doing any homework. learned my lesson, did a little homework, asked around on here, and just placed an order for a new bender from sears,
this link....
http://www.sears.com/shc/s/p_10153_12605_00950509000P?keyword=tubing+bender
which was a hair over 36 bucks shipped. if it works like its supposed to, it will be worth every penny. but its got 5 star customer reviews, and just looking at it seems like it would do the job wayyyyy better than what ive got now.
my only problem now is my brief attempts at using a flairing tool did not go well. the tube dosnt flair, it slides through the tool, no matter how tight i make it. which gouges up the sides of the tube, and dosnt create a flair. i may attempt to use some heat on the tip of the tube when i flair it to make it a bit easier.
this link....
this link....
and i do most of my work alone, not many of my friends are handy with a wrench.
