tuff country 56" springs from ord.. pic of my springs...is this bad..........
down4thakrown
flagstaff,az
i was thinking of buying some 56" tc springs from ord...and i was checking them out and they only sell 4" springs...does anybody else have these? are these meant more for towing then flexing? should i just look for sum off a stock one ton and take sum leaves out?
na....look at my springs there seperated. you can see in between them..doesnt that mean there wore out and guna break soon...?
ya i didnt have shocks on it for the longes time...and beat it up and a center pin broke on of them..i think the side in the picture...is this a sign of them goin to break soon? ther 56" i got used from another k5...anybody know bout the tuff country 56's if there stiff or flex good?
The ones in my burb looked like that stock.. I'm gonna get 4 or 6 tuff country's.. not sure yet.
does tuff country make a 2" i looked on the ord site they didnt havem listed and i sent them a email
That spring is bent (the top 3, anyway) and axle wrap caused it. It had nothing to do with shocks, shocks don't do a whole lot to resist axle wrap.
How much lift are you running? Shackle flip?
yep if irc its a 4 inch lowering shackels and 2" block..........
this is how it sits....with the 81 tub i jus put on......
and im runing a 6" lift...i rotated the front hangers like the write up on her for a 52" swap but kept the stock length on there which i think are 48" right? the are 6" of lift and 35 swampers with 4.56 gears..miller locked 14bff and a spooled d60 up front...
