Well I'm finally getting back to this task.
What I've got.
GMPP 383 - 4l804
620 cfm custom TBI
454 80 injectors
60 psi pump 255lph
18 psi at the (now using an adjustable and stock spring set to 15 psi)
A Harris TBI custom chip (now using a home brew custom chip)
When I last left off, it was well noted that it was rich in just about every area but I can't seem to find the log now. That was probably 16 months ago.
So now, I finally got a couple of melcals solder up with new chips and I'm working with the $85.
I get some logs down tomorrow and go from there. I can see this section has pick up a bit since I left off.
Thanks to Dave and Mark for doing most of the leg work.
What I've got.
GMPP 383 - 4l804
620 cfm custom TBI
454 80 injectors
60 psi pump 255lph
