1...Any of you guys tune your propane kit with an o2 sensor..? Im in the middle of tuning my carb and i was thinking thats a route to go, should help to get it tuned in better.
2.. Any tips on tuning the x450 carb
3...What kind of an initial and total timing do you guys have..?
4... How far away from the carb is your evap..?
I have mine at 10 initial and 24 total right now, with the x450 carb it seems to pull thru some good rpms. I adjusted the mixture by turning it in till it starts to spudder then back out, basicly leaning it till it spudders then richened back out.
Also how are your vac hoses ran and do you run a pcv..?
I havent had much time but im slowly getting to it.
