dave w
I've been tuning on the '427 PCM upgrade http://coloradok5.com/forums/showthread.php?t=270253 using DataMaster. The single wire O2 sensor was not working, because I noticed several seconds of almost 0 volts from the O2 sensor on my first data logs.
So as an experiment, I upgraded to a Heated O2 sensor down stream from the exhaust manifold. I've not seen any of the almost 0 volts readings from the Heated O2 sensor. So far I've only made adjustments to the injector flow rate. It seems the PROM programming (injector flow rates) for a 1995 454/7.4 liter are in the "Ball Park" for the 1987 GMC I upgraded to the '427 PCM. Using the injector flow rates for a 1987 7.4 liter engine showed a lean Histogram. Using the injector flow rates for a 1995 7.4 liter engine showed a rich Histogram.
dave w
So as an experiment, I upgraded to a Heated O2 sensor down stream from the exhaust manifold. I've not seen any of the almost 0 volts readings from the Heated O2 sensor. So far I've only made adjustments to the injector flow rate. It seems the PROM programming (injector flow rates) for a 1995 454/7.4 liter are in the "Ball Park" for the 1987 GMC I upgraded to the '427 PCM. Using the injector flow rates for a 1987 7.4 liter engine showed a lean Histogram. Using the injector flow rates for a 1995 7.4 liter engine showed a rich Histogram.dave w
