Turbo 350 forward drum
Jonathanlackey
Registered Member
Greensboro goergia
Rebuilding turbo 350 transmission and pulled out the forward clutch assembly. All the springs were not in the right place most were stretched and/or bent and some were broken. So definitely replacing all the springs and bolts he piston assembly but I’m not sure if the drum needs to be replaced or not. And if so where is the best place to get one for the money.
Check Rockauto. My son has found some good deals there, even on Sonnax parts for his transmission.
If you don't see it by application, find the part number on a different site, then enter it into the search on Rockauto.
No guarantee, but worth a look.
