Turbo 350 kickdown question
85 Jimmy
Sheepdog
Gulfcoast
Does anyone have a picture of a turbo 350 with the pan off? I'm trying to hook up the kickdown cable in an ElCamino and there is nothing there for the cable to hook to. I dropped the pan and it's not in the pan either. I'll take a picture and post it up.
iirc there is a long metal wire with a hook that goes right up near the hole were the cable goes and this is were it hooks to. You must be missing the wire linkage that is connected to the valve body.
Kinda like this thingy
iirc there is a long metal wire with a hook that goes right up near the hole were the cable goes and this is were it hooks to. You must be missing this
Yeah the metal wire thing hooks to the lever that I pointed out, but from this picture, the angles don't seem like they would work.
when I took these off, I always kept the metal rod on the cable, not on the bottom, just like in this pic.
