nicks
Registered Member
I am thinking about putting a 241 behind a turbo 350 and before I buy everything, I was hoping someone could tell me if they will bolt up. My biggest question is are the tailshafts in 700 and a 350 the same length? If so, then would a pass drop 27 spline 241 case and adaptor bolt onto a 350? My 203 adaptor looks about half as thick as a 241 adaptor and makes me catious of buying an adaptor and case. Or if someone has put a 208 behind a 350 trans could they let me know if it was a bolt up affair.
, and cut the one you have. To replace the output shaft, you'd have to disassemble the trans. Thats cool too if you want to overhaul it anyway.
