onebig76k5
Registered Member
Just had a body off resto done on my K5. Tranny had no issues prior to resto and has about 20K miles on rebuild. Tranny Shifts fine through gears unless you stop and turn off ignition (Operating temp). If you restart say within 5 minutes put in drive, the tranny does not want to shift out of first gear. It will but you have to drive it a ways. It does not have this problem unless you turn the iginition off. I can stop and start and it shifts fine. I did notice there was extra fluid in the tranny but I have drained to operating levels.
