I have this small 2.2 litre Yanmar diesel engine, it came off my reefer unit and is almost new but CA air resourse board thinks we are made of gold and we should be replacing our engine every 7 years so I want to get good use out of it.
I want to put it in a car or a small pickup or even a Sammy, but with no Turbo I suspect I will not be very happy with it.
I still have to figure out what tranny to put behind it, thinking a 700R4 should do the trick.
Now the Turbo shouldn't be to hard to mount at the end of the manifold, but I have no idea for sizing.
I know the engine can turn 3000RPM and has about 90lbs of tq.
I want a bit more but have no idea what to use, thinking a wastegated setup could get more off the line and then keep the pressure regulated thru the wastegate throughout the powerband?
I know a smaller impeller works faster, but how much?
ANy help appreciated.
I was thinking to strap it on a dyno first and see what I have to work with then start a test chart.
Also should I figure out the tranny first and then start working off the output on the tranny or work from the flywheel numbers?
