Muddytazz
1 ton status
The wires coming out of the wand and running down the inside of the column, what do they control? This is for a wand that has intermittant wipers and it has cruise.
They affect only the cruise control operation. The wiper switch itself is mounted to the bottom of the stalk, and the stalk presses into it. Without those wires there will be no cruise function.
No, the wiper switch itself is the part that the stalk presses into. If you look at like LMC for the stalks, you will see that only the stalk with cruise has wires on it, while the wiper only stalk has nothing on it. The stalk presses into the wiper switch, and you have to tear most of the upper part of the column apart to get to the switch.You sure those wires don't control cruise AND wiper function?
