Turn signals don't work
jahin77
Registered Member
Texas
I have been having a problem with my turn signals for about a month now. I have replaced the turn signal flasher fuse and they still don't work. I know the bulbs are good because I can use the hazards without any problems. I'm not sure if there is any other fuse that has to deal with the turn signals. It could be the switch in the steering column but if it was bad I don't think the hazards would be able to operate. I would like to hear your input.
2 flashers, one for turn signal and one for hazard.
Also I believe there are 2 fuses.
If all this checks out check for grounds.
And if the turn signal stalk is the problem the hazard will still work.
The only thing it proves is that the bulbs are good.
Yes, I changed the the turn signal flasher and not the hazards one. The next plan of action is going to change the turn signal switch in the steering column.
The one time I ran into this problem, it was a bad terminal for the flasher module. You might have to pull apart the fuse block.
Come to think about, I think I replaced the whole in cab harness since it had other problems.
