Turn signals work with lights off......won't work with lights on
dawson444
Raleigh, NC
Turn signals work with lights off......won\'t work with lights on
My turn signals work fine normally. Then when you turn on the lights and the left arrow lights up kind of dim, and neither one of the turn signals will work. Please help! Thanks!
Dawson
Raleigh, NC
88 K5, 6" lift, 36" TSL Radials, 14 Bolt, Rancho 9012s
Re: Turn signals work with lights off......won\'t work with lights on
Sounds like the parking light circuit is somhow shorted to the signal circuit. Make sure the bulbs are in corrctly and the sockets are nice and clean. Check the side marker ligths also.
Michael
<a target="_blank" href=http://www.jmartin.net/parker/goose.htm>www.jmartin.net/parker/goose.htm</a>
Sounds like the parking light circuit is somhow shorted to the signal circuit. Make sure the bulbs are in corrctly and the sockets are nice and clean. Check the side marker lights also.
Michael
Check your body grounds. In particulare the ground strap off the passenger side head to the firewall. Why it works with the lights off is it is pulling ground through the lights on the core suport. Once the lights are turned on the route is gone so it quits.
Women dig dents and flat paint!
coloradok5.com/gallery/Grim
75 Jimmy, Dollar
Grim-Reaper
Make sure that your tail light and grille light park/turn bulbs are dual filaments. I've seen a single filament bulb mistakenly put in and it does the same thing.
Haze gray and underway...<font color=blue>or blue, in my case.</font color=blue>
<a target="_blank" href=http://community.webshots.com/album/26246038MbQsYWKcbo>U.S.S. Nimitz II</a>
you happen to have the wrong (or faulty) bulbs in the parking/marker lights front or rear?
Dorian
My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
Why insist on counting when the ring gear has the tooth counts stamped in?
