I need to turn the engine by hand. I have the flywheel cover off. Which direction do I need to turn it? Which direction does the engine turn? 1978 chevy 350.
Standing in front of the engine does it turn clockwise or counterclockwise?
....dont try using a strap wrench on the outer diameter of the balancer either,it might make it slip on the rubber insert and ruin it...you can turn it by grabbing one of the pulleys though,they bolt to the solid center of the balancer...you can often turn the engine over with a wrench on the altenator pulley nut usually ,without hurting anything..
