Turning engine over by hand
wazzabie
Washington State
My 350 has been sitting for along time in the k5. I want to turn the engine over by hand and put some oil down the sparkplug holes. It may be several months till I get it running again as the carb is off. Please advice me how to turn the engine by hand. Or am I best to charger the battery and turn it over? Is it ok to do this with the carb off? What problems could this cause? How do i do this? thanks
If it has the flexplate on it you can jest grab hold and spin it. Ive done that a few times... tho it is much easier without plugs than with.
:haha: :haha: :haha:
Which direction to turn? Could turning this bolt cause it to tigten and get out of spec? Would you provide me with a picture of where this bolt is?
I turned my 502 (11 to 1 comp) by the flexplate too, it was hard but it worked. :crazy:
I don't usually turn it by the crank bolt in fear of shearing it off in the snout of the crank. I typically turn one of the balancer bolts that hold the pulley on instead. They are 9/16th on most of my engines. If one of those shears off, its far easier to fix than one sheared off in the crank snout (which I have done in the past, NOT FUN!)
So maybe I should just charge a battery and turn it over as the safest option. It has no carn on it. Any potential problems with this?
If it has been sitting for a while, I would definitely reccomend that you turn it by hand for at least one full revolution. That way you can feel if there is anything in the engine. You don't wanna hit the starter, and have a piston smack and bent a stuck valve or something. If you don't turn it by one of the balancer bolts, like mentioned above, just crawl underneith, pull the inspection cover for the flexplate, and turn it by hand. On a relatively stock engine, it isn't tough to turn. Just use a pair of work gloves, so the teeth don't bite ya, lol
Thanks for the help. The inspection cover/ flexplate... is this this cover silver in color? I would turn the flexplate(has the teath which connects to the starter) which is behind the cover? Should I also remove the starter? Which direction should I turn it or does it matter? Any chance that the engine might start? It has no carb so I hope not.
Most of the time its grease colored, lol, however, that is probally the color on a newer engine :) It'll be located between the oil pan, and tranny pan. It is held on with two 7/16s (I think) bolts on the tranny, and two on the engine. Make sure you pull straight down, and try your best no to bend it on the starter. Once thats off, you'll see what we mean by the flexplate. It'll be the part that has the round torque converter bolted to it. You will not need to disconnect the torque converter, or starter. You can turn the engine by hand which-ever direction you want, won't make a difference if you are just giving it a turn to feel if anything is stuck in there. The engine will not start with no carb, and the plugs pulled out :)
