turning radius
hd44blazer
Antioch, CA
I've just finished installing a 6" lift on my '79 K20 and noticed when turning to the right, the amount of steering travel has decreased by probably about half. I have the raised steering/knuckle arm installed and wanted to know if I should also install a drop pitman arm or have the adjustable link that connects the pitman arm to the steering/knuckle arm adjusted. And I don't want to go to x-over because it's not in my budget. Thanks
NM, I adjusted the draglink and it fixed the problem.
