Folks, I make no claims as to the accuracy of this. I didn't write it, or know who did.
But, it makes perfect sense, explains why adjusting the TV cable is so important, and brings up a possible problem I have not seen discussed anywhere here.
May have been, and I just missed it.
I actually like the "click" method of adjusting better than his, but each should work.
The reason I posted this, was the geometry problem. I have seen postings where people have added spacers and had linkage problems plus transmission swaps and having to add a TV cable.
It looks like its not just the position adjustment that is critical, but the amount of movement of the cable per throttle movement that can be a transmission killer as well.
Sounds like someone needs to buy a pressure gauge, check his pressures, and then pass it around the brotherhood.
If everybody with one of those trannys chipped in a buck, you could not only buy a darn good gauge, you could probably throw a bar-b-que......
Just a thought...........
Here is the link.
http://www.jakesperformance.com/TV_Cable_Setup_Info.html
Here is the link.
