adamforsythe
Tell me what the cable does. I believe it just kicks the tranny down to the next lowest gear when you are at WOT.
Thanks
Adam
Thanks
Adam
It combines the functions on the heritage trannys (TH350,TH400) of the kickdown cable and the vacuum modulator.adamforsythe said:Tell me what the cable does. I believe it just kicks the tranny down to the next lowest gear when you are at WOT.
Thanks
Adam
big83chevy4x4 said:that is correct for a th350, (which is called a kickdown cable), but for a 700r4, it overates the throttle vavle and adjusts shift points and firmness acording to where the throttle is. kinda like a Throttle position sensor for the tranny.
if you don't hook it up or is not ajusted correctly, it will kill your tranny FAST. the more missadjustment, the faster it will kill it.
Adam, what tranmission are you enquiring about?adamforsythe said:So if I do't have it hooked up on my TH350 it will kill it??????????????
Thanks
Adam
Sorry 'bout that, when you started the post with "TV cable" you automatically programmed "us" to 700R4.adamforsythe said:I see..........my bad.
Thanks
Adam
roadnotca said:Sorry 'bout that, when you started the post with "TV cable" you automatically programmed "us" to 700R4.
Like my engine?![]()
