protechk5 1/2 ton status Joined Sep 26, 2004 Posts 2,015 Reaction score 0 Location VA Mar 29, 2008 #1 Can you install the new shift rails while the 205 is still in the truck, if you have a removable hump?
4X4HIGH 1 ton status GMOTM Winner Joined Dec 14, 2001 Posts 22,423 Reaction score 662 Location Fremont, CA. Mar 29, 2008 #2 protechk5 said: Can you install the new shift rails while the 205 is still in the truck, if you have a removable hump? Click to expand... No. The t-case sits too far back (even with the removeable hump) to be able to remove the roll pins from the shift fork.
protechk5 1/2 ton status Joined Sep 26, 2004 Posts 2,015 Reaction score 0 Location VA Mar 29, 2008 #3 Alright looks like its coming out then, thanks man.
