two bolts on transfer case brace wont come off?
RyansRod
Bay area CA. USA
Have an 84 K5 with NP208, Trying to get off two bolts that keep the transfer case brace on the transfer case. The brace bolted to the case and the engine block, but won't come off the TC. Are these bolts reverse thread or what their on there tight!
Friends don't let friends drive fords
Not reverse threaded, just the aluminum-steel interface/corrosion. Mine took some careful work with the "attitude adjuster" (4lb hand jack) then they came right out. Good luck to ya!
......And knowing is half the battle
<a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
