U-Bolt nuts rear axle
Ralph the german
Registered Member
Germany
Hi guys,
is this the right thread of the nut from the rear axle of my 90 Blazer full size ?
Working on traction bars today and need new nuts.
5/8" - 18 UNF 0,625 15,875 14,50 18 1,411
thanks
It's going to depend on the rear axle you're using. I know that the 14ff uses a 5/8"-18 nut but i think the stock axles used a 9/16" nut. Someone else will chime in and correct me if i'm wrong.
Have a 4" lift, d´nt know that this u-bolts are in same dimension as the stock.
But 9/16" cannot, they have an outer dia of 14.288 mm, my u-bolts have an outer dia of 15.8 mm I measured.
