u bolt torq ?
blazenbaja_67
Carlsbad n.m.
just picked up procomp spring ubolts and was wondering about there 55-65 ft lbs of torque the factory is 140 so is 55-65 going to be right just wondering
that is what i do but they sent this dirction sheet that says 55-65 ft lbs and that just doesn't soun d right and they arn't answering at tech line
What diameter U bolt is it? Most of them torque to 140 lbs. like you said and that's what mine are torqued to.
it is 5/8 bolt with high hat nut they finaly called back and said 135-140 with out degree shims so it isnt adding caster but i can align that out
