U-bolt torque specs
kpanza
Lake Forest, Orange County, California
Just wondering what most of you use for a torque setting on your u-bolts? I have heard of wildly fluctuating numbers here, and I can't seem to find a definitive answer yet. Is it the 90 lbs someone told me, or all the way to 150lbs another person swears by? I think 150 would be excessive, but I did 100 last night after changing shims and it seemed like it might need a bit more? By the way, this was on the rear 14 bolt if that makes any difference (doubt it will) with quality Deaver made u-bolts...
I torque mine to 140. Duno why I do, that is just they way i've done it. Someone somewere must have planted that number in my head years ago.......
72K5
Led Zeppelin
Rock ON!
<a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
RFT!
Haynes says 150, lift kit said 110-120. So I go happy medium 130 ish. But RFT!!!!
Just say no to crack(s)
<a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
Whatever the value, always remember to retorque after initial 200 miles or so and/or after heavy wheeling.
There is a Right way, a Wrong way, and then there is My way. The latter is usually the most fun!
150 here...........again, someone planted that number in my head years ago...........
<font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
I think my factory manual says 140, but the lift kit did say 110, i usually go with the factory, unless i'm feeling weak.
Leland aka RaisedK5
"Of all the things I've lost, I think I miss my mind the most!"
"Are the voices in my head bothering you?
