wasted wages
1 ton status
I pulled the rear driveshaft out of my dually tonight to change the rear u-joint.
The factory joint doesn't have snap ring clips on the yokes,,,,the grooves are cut in the yokes,,but no clips...The new joint has clips in the box...
There are a couple of little plastic looking pins sticking thru the sides of the yokes next to the caps....do I need to heat them and melt them out ??
I tried to drive the caps out with a socket and 2 lb sledge but they wouldn't budge,,,,am I missing something or do I need to press them out ????
